Bad news for lithium...
Eggroll
RingsOfSaturn>your music
Heard from my buddy that:
"lithium batts only have so many hours of play time till you need to plug them into a lithium charger, and that regular alts don't charge them properly. Takes like 3 hours of alt charging to get them to good enough capacity vs the 1 hour of charging with a charger"
Is this true?
Kevin at jb said otherwise and theyve been around long enough for this to have popped up. I wouldnt listen to your buddy completely.
His direct statement
"No special charger will be needed. Lithium actually holds up better than lead acid when sitting. You can use any lead acid charger to top it off as well. Mixing with agm's is just fine as well. "
His direct statement "No special charger will be needed. Lithium actually holds up better than lead acid when sitting. You can use any lead acid charger to top it off as well. Mixing with agm's is just fine as well. "
Idk Kevin at juicebox told my buddy to get this ctek 12v lithium charger for his lithium 12v batts when he had it. Lol but my buddy only had lithium... He wasn't mixing with agm batts
you could talk to the actual manufacturer.. who knows about the specific cells being used in their batteries... not necessarily a one size fits all approach for lithium 'yet'
there's a lot of different types
I was gonna do that but was a afraid of a "if you don't know don't get it" response (like when asking about wiring low)
when talking to the manufacturer? be up front with them then, ask for an explanation of what cells they use and how they work with other batteries and your specific electrical, whether it be high output alternators or batteries. i like to come off less knowledgeable than i am sometimes when talking to a company, just to see if they give me ********. if they explain things and legitimately know what they're talking about its usually a good sign. call an alternator shop and they dont know what specific regulator, stator, and rectifier they use then i dont understand how they can back their product
Very true and valid points sir, I agree. Thank you sir!
Got a LONG way to go if you or at least the friend believes that about lithium in terms of knowing how lithium should be treated..
Seriously, that's ridiculous.
Ask your friend if he knows if you are suppose to charge lithium batteries up to 100% or not?
Simple question? See what he says.. His answer will dictate his knowledge on lithium- and i assume we are talking about 4SLiFePO4s, correct?
Even I know that no one should ever charge lithium to it's maximum, nor have it discharge to unsafe low volts. I now agree with my original thoughts that using lithium should be fine as long as one knows what they're doing
My 2 - 15" wedge box is around 5 cubes net with 80 square inches of port. My 4 - 8" wedge box is 3.69 cubes net with 43¾" square inches of port.
7
338
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
9
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
Eggroll
Eggroll
Death Metal > Your Music
audiobaun
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
