what amp for a xxx18
First of all, 12.1's arent gonna put out 1500-2000wrms, so that doesnt help me. 2nd of all, I know they arent the greatest but why dont you make a suggestion and not be an @$$hole...Sound good?
what about the eD 9.1, would the be strong enough? i know is rated at 1200, but thats at 12.5 volts. probably a lil stronger at 14...
its around 1400-1500rms at 14.4 volts for the 9.1 hifonics is crap maybe there brand new ones that just came out. a bx2000 will only put out around 1500-1600 and how can you guys say lanzar is crap its the only amp on his list that will actually do's its rated power except for the 9.1. But the lanzar is rated at 2000 at .5 ohm not 1 at 1 it will probally do from 1600-1700.
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
238
443
Josh #44
I'm kind of a big deal...
Josh #44
Pocola, OK
germanyt
Decebal
    Jun 10, 2024
