What amp is better JL jx500 or mrx m50 from alpine
  • 4
What is the voltage of your head unit's preamp? The alpine can only accept input of up to 4 volts, I'm not sure about the jl, however.
Unless you've got a 20v signal I don't see a problem. Even then "problem" would be subjective.
A 20v signal with the gain set at 4v would be like the common newb running the gain peaked with a standard 2v preamp. You just run into clipping before full volume. It's not like the input stage will burst into flames.
There's plenty of monoblocks that are legit rated a fck load more than 1200w...
6
167
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
359
6
471
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
759
juen45
juen45
Laredo, Tx
n2audio
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
