What amp(s) should I get?
  • 2
I saw the same subs get put with a Taramps HD8000, two XS Power D3100 batteries, and a 270A alt. Would this be a decent build for these subs and would there be too much power consumption with this?
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
3K
Your skar amp will catch on fire if you go full power?
8
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
CodyDaGoat
CodyDaGoat
OR
hispls
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
