What amp should i get
  • 4
how far should i turn it down?
sorry for the questions but this is all brand new to me
Use a volteter set to ac voltage on the speaker outputs without the speaker hooker up and use this formula
Volts(ac)=√(watt×ohm)
20(VAc)=√(400×1)
Set the amp to 20v ac on the amps output. Adjust the gain until it's at 20v ±1v
20(VAc)=√(400×1)
so for my car it would be 12v+_1v because i have a 12 volt battery?
Yes
ok so then that will turn the amp down so that i can use it with the sub
That will set the output to 400w any any extra eq will just eat into the headroom which is fine. The sub should take slightly more than RMS power without issue. Then later you can upgrade to a larger sub if wanted and still have power to spare
Yes
ok i understand it now thank you so much for your help
would you recommend this over the d4s jp8?
I would recommend this over the DFS JP8 for the money, or spend $10 more than the DFS JP8 and grabb a 1500.1
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
Have you check to see if the prefab would fit...
13
Your skar amp will catch on fire if you go full power?
8
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
Not to be that guy but............Clipping occurs when more power is required from an amplifier then it is able to deliver. Once the maximum...
15
turb00
CarAudio.com Newbie
turb00
harleysville
audiobaun
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
