What amp(s) should I have to run 4 Infinity Perfects 12.1?
  • 2
I have four Infinity Perfect 12.1 in my Dodge Dakota Extended cab 4x4 truck. As of right now, I have two of the four speakers hooked up and those two are running off a Punch 500. I am wanting to buy some amps but I am not sure on what to buy. I need some help. I know I need alot of watts to push these four Perfect 12.1.
Please help me.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
8
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
wiseradam77
wiseradam77
Shelbyville, IN
mykeys
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
