What amp should I buy
I just bought a comp vr 07cvr122 - 12" 2ohm DVC sub
And I don't know what amp I should buy to power it.
Here are some specs of the sub
12-inch CompVR Subwoofer with 2-ohm impedance
Injection-molded cone with 360-degree back bracing and aluminized coating; ribbed Santoprene surround
400 Watts RMS (800 Watts peak) power handling
25-500 Hz frequency response
Also, I have a couple RF p1's and p2's and a MTX, they are each different ohms, is there any way I could also hook them up with my comp vr? or would that not be a good idea?
I would only want 2 subs total. But they're not 2ohm like the compvr
Don't use different subs.
Buy this: Crescendo Audio :: Amplifers :: 1000C4 4 Channel Amplfier
It's more than enough power for the sub, and you'll have power left over for your front stage.
this
use the compVR and the front channels for your mids.. all in 1 amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
when you upgrade the substage you will gain 2 mid channels to bi amp some nice mids with //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i had one of these hooked up to a sub this past year and did a 145 verified at a 3x dbdrag show. They are great amps for the price they are hard to beat and they are very versatile and forgiving as well.
My advice is always solid. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Have you check to see if the prefab would fit...
13
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
kyle372
kyle372
Oklahoma City, Oklahoma
misfit138
