What amp should I get to run this sub?
  • 2
If you wire it in parallel, it should bring it down to 2-ohms. Then you run can run any amp that is 2-ohm stable. The subs are only 300-watts RMS so any 500-watt RMS amp is plenty for them. It really comes down to your budget. I'm running a MB Quart DSC1500.1D, its a decent reasonably priced class D sub amp. I had an old SoundStream Reference 500 (1st gen) that would've sounded awesome with that sub, but sold it last year.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
netsfan549
netsfan549
Passaic,NJ
netsfan549
