What amp should i get under $150
  • 4
TJ2Basic
I just purchased a brand new American Bass E1224 for $85 which in my mind is a steal. But idk what amp I should get to pair up with it, I'm trying to stay below $125 preferably, but I'll go up to $150 if I have to. Also would I need to upgrade my alternator or power system in order to run the sub?
That sub can take over 1000wrms? And it's a dual 4 ohm coil?
Damn....I would put a 2000wrms @ 2 ohm amp on that.......but it will cost WAY higher than $150.
I mean you could also take a 1000wrms amp and tune it with a -3db or -6db tone to get that most out of it, but again at 2 ohms, you may have to spend more.
I'll suggest a JP8 amplifier.
I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct?
JP8 @ 2 ohm does 900 watts.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
134
TJ2Basic
TJ2Basic
United States
some dude
