What amplifier would i need for 2 10 inch JBL subs?
lulwut
the subs have RMS of 275W each and peak power of 1100W each. theyre gonna be put in the trunk of my acura tl so i dont need them at their peak but i want a quality bang out of them. so what amp sort of amp should i get for cheap? and should it be two channel or what? i have no knowledge in this area please help. the more specific the better
What's the voice coil configuration for each sub? Single or dual voice coil? 4ohm or different? Use a mono amp regardless, we just need to find out what ohm load you'll need the power at.
Get a mono amp that does 500-750 watts at 2ohms, and you'll be set. There are JBL and Kicker models that do that if you're interested in staying mainstream.
how do i know if an amp does 500-700 watts at 2ohms?
931
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
3K
Here is my thought, theory. Those speakers are 80w rms. Half of that is 40w rms. Add the 40 to the 80 and you get 120w. Get an amp that is 120w...
I have 2 Sundown SA10v2 (1000w version) and just replaced my RF R1200 with a T-1500.1bd and OMG! I was considering Ampere Audio, JP23, Sundown...
5
Hmm. Maybe so. Ive never been more alert driving/riding than being on a Cycle man. Several think you just get on and ride away. A good set of...
26
5K
lulwut
lulwut
Chicago, Il
matt_bennett05
