What AWG is needed for @400amp?
  • 3
diehappy
So, I had an audio shop setup my system. I paid them to do it and figured they would run what was needed.
I have a Audio Control 6x1200 and a Taramp Smart 3k. The alternator is CES 370amp.
They ran 1/0 CCA with a 300amp fuse.
I know or feel this isn't good enough. I bought a Limitless Cyber 6k to put in the vehicle. I will bypass the stock battery and run off the limitless. I was wondering what I should replace the wire with and fuse. I will probably run the wire into truck/limitless. Then take off that to the amps. I was also thinking of leaving the 1/0 in place and connecting that to the stock battery from the limitless but removing the negative from the stock battery and leaving that in place for backup. Thanks guys.
Should the fuse be upgraded as well if the alternator is capable of up to 370? Sorry if questions seem dumb. I have done some research I just like making sure best i can from experienced people. Thanks
Yes. I would put a 375 or 400 amp fuse in after upgrading the wire. Not at all your questions are perfectly fine.
It should work well enough for you to get solid connections. That’s about the same price I paid for this one, and I‘d bet all the cheaper...
12
  • Locked
Thanks for the quick rep and it was great chatting w/ you. Good luck w/ what we discussed. It rare but sometimes I stumble across odd and ends...
18
3K
Run 4g for power (or 1/0 if you can). There is no downside to bigger wire, and you won't have to replace it if (when) you go bigger. Speaker wire...
904
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
496
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
diehappy
diehappy
Daytona Beach, FL
Buck
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
