Wiring Voice Coils Separately?
  • 3
Both terminals on your monoblock go to the same channel. You can either wire it to the amp using two sets of wires for the voice coils, or connect the wires together closer to the subs. Just depends on preference, if you're short on wire, if the wire's too small, factors like that.
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
107
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
363
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
356
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
4
671
bigman357
CarAudio.com Newbie
bigman357
MN
jt4x4
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
