What do I need?
  • 3
invertMASA
Im working on putting a new sound system in may car, Its a 2010 impreza sport. What would the adapter be I need to get RCAs and keep all 4 channels? I found some but they only splice into 1 speaker, so that would just send that channel to the amp and thus so all the other speakers giving me a mono sound right?
Want to keep it looking stock. So dont want to buy a new deck
if all you are planning on doing is a sub and amp then that will work. if your looking into upgrading everything but the head unit I'd go with a processor. Processors can be expensive though, pricing from couple hundred to a thousand. do some research on processors within in your budget and check back before you buy. At least I would suggest checking back before you buy.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
140
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
193
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
146
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
503
invertMASA
invertMASA
United States
CrossoverOre
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
