What do I need?
  • 2
jaredmonk
helena
I am installing my system. It consists of the Pioneer 7300 cd player. A Rockford Fosgate Punch bd 1000watt amp. And a Kicker L715" Solobaric. I also have the mount for my Suburban. (for the cd player)
What do I need now for wiring and such? My local car audio guy. Said he would install the deck and the amp with all the wiring for 110.00. Does that seem reasonable? It seems a little high to me but i dont know?
THanks
If it includes the wiring kit for both the amp and the CD player then it would be a good deal. A wiring kit for a 1000 watt amp would generaly run about $50-$60 alone. If the $110 is labor only, that's average. The local shops around my area generaly charge $55 for a 2 channel amp and $45 for a CD player not purchased in their store. This usually covers a CD HU wiring harness and basic labor only. Not the amp wiring kit.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
157
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
116
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
464
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
356
jaredmonk
jaredmonk
helena
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
