What do you all think of this new setup in my Mini Cooper 2010?
andddlay
12
Michigan
Hello all! First post here //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif so sorry if this is the wrong place to post this.
I'm a big noob at this whole car audio deal. Just wondering what you all think of this setup, and if I purchased everything (mostly everything is currently in the mail):
New dash kit to fit the head unit
Pioneer AVH-P5200BT head unit
VLYNX HEAVY DUTY 12" Sub Woofer Box Enclosure 3/4" MDF Slim Truck Box (not sure if anything else could fit)
Infinity KAPPAFIVE 50W x 4 + 350W x 1 Class D System Amplifier
Boston Acoustics ProSeries 60SE - Car speaker - 125 Watt - 2-way - component
Boston Acoustics SC60 6.5" Car Audio Component Speake
Boston Acoustics G112-44 (is this powerful enough? not sure if anything else will fit unless I take out a seat)
Metra 70-9003 Radio Wiring Harness for Audi/BMW/VW 2002-Up
Super Cable, 14 AWG, 50 ft., Clear SC1450
MTX PSK04B Single Amp Kit 4 Awg
Thank you //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
ok why buy everything and then ask about it? why not ask about it 1st before you buy? did you measure the space behind the back seat? this sub will not work very well, it's only a 50rms sub, your amp puts out 350rms. plus it's right at the mounting depth of the box, so it may or may not fit. it might run hotter because of this also. i would suggest measuring the space you have for a sub 1st then find a box to fit that space and pick out a different sub. if you either don't have the room for anything bigger or just wanna stick with that box, then i'd return the sub and pick up this one instead. Amazon.com: Kicker 10cvt122 12 Subwoofer 2 Ohm Compvt: Kitchen & Dining
the rest is good i'd run with it.
ok why buy everything and then ask about it? why not ask about it 1st before you buy? did you measure the space behind the back seat? this sub will not work very well, it's only a 50rms sub, your amp puts out 350rms. plus it's right at the mounting depth of the box, so it may or may not fit. it might run hotter because of this also. i would suggest measuring the space you have for a sub 1st then find a box to fit that space and pick out a different sub. if you either don't have the room for anything bigger or just wanna stick with that box, then i'd return the sub and pick up this one instead.the rest is good i'd run with it.
True, it was rather silly asking, but just thought I'd run it by you all. My apologies.
The box fits - it already arrived at my house, so no troubles there. And as for the G1 rms rating, according to Crutchfield, they have it as 50-200rms. This shouldn't be a problem then, right? Again, forgive me for my lack of knowledge in this area.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
620
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
943
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
andddlay
andddlay
Michigan
lilboom
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
