What Fuse To Use?
  • 5
venoxcide
US
Hi,
I'm doing an upgrade to my system and I'll be running two amps:
1) Mids/Highs: Pioneer GM-D8604 - It will be doing about 300-350W RMS of output.
2) Bass: Pioneer GM-D9601 - Around 600W RMS of output. (I know this amp goes way higher but I'll be matching to my subs)
I already have a 120 amp ANL fuse and I'm wondering if that should be fine, or if I should pick up a 150 amp one.
I'm asking because the bass amp has 3x 40 amp fuses on it, but for 600W it shouldn't be using anywhere near that for a Class D?
Also, I'm using two 300W RMS SVC 4 Ohm subs so when I put them on the amp it should get a 2 Ohm load right?
Thanks alot!
What subs are you using? You could probably push more than RMS to them if it was clean.
2x Pioneer TS-W304R 12". They're rated for 300 RMS each. Maybe they could take 400 if clean but I don't know.
They can take it. Just don't expect them to handle it below box tuning.
---------- Post added at 03:09 PM ---------- Previous post was at 03:09 PM ----------
Also, fuse to the wires capacity.
Running a sealed box for the time being. I want to get a really good custom ported one made but I don't have the time or money right now so I just stuck them in a decent sealed one.
Do you have any recommendation on the fuse? Is 120 amp enough or should I get one of the 150s?
EDIT: Alright thanks!
if you switch to a ported box, you're going to have to lose that amp. It doesn't have a subsonic filter built in. And those Pioneers do NOT like playing heavily below tuning. If it were me, I wouldn't even port them. Sealed is your friend with those subs
The 120a is fine because that amp will never pull over 120a daily. Usually around half of that
What size wire? And what brand? Make sure whichever brand and size you're using can handle a 150.
Well I haven't actually bought the amp yet, I'm ordering today so what amp would you recommend that will push those subs to their full potential in a sealed box and have a little headroom for future upgrades?
Its a KnuKonceptz true 4 AWG 100% OFC power wire.
I just replaced my original DB Link CCA 4 AWG with this and its definitely thicker and heavier.
That amp says 600W RMS @ 1 Ohm.
My subs are 4 Ohm each SVC so the amp will see a 2 Ohm load when both are connected. That amp at 2 Ohms is only 300W RMS.
Are Hifonics amps any good? I was looking at the Hifonics ZRX1816.
I want something a little more powerful than exactly what the subs are going to require because I'm definitely going to keep upgrading over the next few years.
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
267
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
631
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
venoxcide
venoxcide
US
audiobaun
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
