What happens if i push a 2 ohm speaker with a 4 ohm amp? Is this true from MTX "Wiring subwoofers to the wrong, or unmatched, amplifier impedance is a VERY common cause of blowing amplifiers and burning voice coils in subwoofers" or is this true from sonicelectronix.com "If you’re not an audiophile, does this matter? Honestly, no it does not. Do not let this be a make or break when looking for sound system components. Two of the same subwoofers, just with different impedances, will produce almost the same sound if they are run at the same wattage."
Thanks.
Thanks.
