What kind of amp to get?
  • 4
The door speakers I want are 4 ohms with 45 watt rms and 135 peak. And the sub is also 4 ohms with 250 watt rms and 1000 peak. But the rear deck is 2 ohms at 200 rms and 600 peak. What kind of amp
can I get so the ohms match up? Or do I need to get 2 separate amps? Maybe a 3 channel for the door speakers and sub and then a 2 channel for the rear deck?
Rings? I've had to make them before because the factory speaker mount was plastic, and I've had to make them so the windows would clear the...
218
420
498
JScullari
JScullari
New York, New York
garychoffmann
