brian84corvette 10+ year member
did you crawl under the truck and have a look for your self ?
if your engine is BURNING the oil - then yes its done.
but if its just leaking
it could be from a fiew problem areas - like the front and rear main seal would be terrible
did you crawl under there with a wrench and try and tighten up all the bolts holding on the oil pan and **** ?
check around for other areas leaking out oil... maby its something stupid like a oil preassure sensor that is leaking like a std
or maby the motor is done... investigate
