what should I do with my truck?
did you crawl under the truck and have a look for your self ?
if your engine is BURNING the oil - then yes its done.
but if its just leaking
it could be from a fiew problem areas - like the front and rear main seal would be terrible
did you crawl under there with a wrench and try and tighten up all the bolts holding on the oil pan and **** ?
check around for other areas leaking out oil... maby its something stupid like a oil preassure sensor that is leaking like a std
or maby the motor is done... investigate
I had a mechanic and a person to look at it. Both of them said the bottom end was toast. Dunno how much it would cost to redo the whole bottom end. Doesn't burn oil.
Hmmm. A leak does not signify the bottom end being "toast" at all. A leak is a leak. If you threw a rod through the pan and it was leaking that would be a different story. Get under there and see where it is leaking from. Most likely the rear main. You can just keep re adding oil....
the oil drips right onto the front cross member. like not on the back of the engine in the middle. And you hear it knock when running. Sounds like it's gonna blow up if you give it some gas.
u can easily find an engine, harness and trans, say an ls1 and replace it all.
usually junk yards have good deals, and craigslist has even better ones if u can find them.
not when your in Northern BC where there is nothing good to be found lol. Not by any big cities. Like my city is almost by alaska.
I agree........4.3s are not great engines for trucks
but for the dollar Id dump the whole truck , its too old
to put money into it...or seal it up yourself....
The CT's are nice, That Sundown is a a frik'n beast!
956
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
777
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
913
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
Juice0723
Juice0723
Canada
Ignatowski
Decebal
    Jun 10, 2024
