What should I set my high pass to? JL XR650-Csi components.
comp2007
I was wondering what would be safe for these components, they are being pushed to 70watts RMS with my alpine four channel amp. I have them crossed over at 100hz right now and was thinking about switching to 80hz. Would that be ok?
Are you refering to these? JL Audio XR650-CSi XR Series 6-1/2" Component Speakers System (XR650CSi)
Says Frequency 48 Hz - 25 KHz ± 3 dB
Do you have subs? If so I'd just leave it at 100, if not set it to 80 it shouldn't hurt them. Listen to something with bass, turn it up to max listening and see if they distort, which they shouldn't.
**Edit** noticed its actually a package which includes tweeters. To be honest I'd say leave it at 100 to be safe. But its up to you if you want to test 80.
Yes those are the ones, I think I will just leave them at 100 then. I do have a JL 10w7 in a ported enclosure in the trunk so I probably wouldn't even notice a difference. You guys are crazy lol
lol misfit138 is having too much fun.
@comp2007 when I gave the frequency I am assuming that that applies to the 6-1/2s and not the tweeters, most tweeters ive seen are 100hz since its not necessary for these speakers to produce bass. But anyway you are correct, you probably would not hear any or at best, much difference since you have a sub.
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
906
The CT's are nice, That Sundown is a a frik'n beast!
7
949
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
774
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
comp2007
comp2007
Phoenix,AZ
Jeremy M
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
