what size box for 12" hifonics hfi?
  • 3
2.25 after displacements tuned to around 33-36hz...fairly generic box for decent results. I'm to lazy and cold this morning to look up the sub.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
eggyhustles
eggyhustles
Bronx, NY
pro-rabbit
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
