What subs do i go with now that i have this amp?
  • Thread starter <Runninhorn>
  • Start date
  • Replies 4
  • Views 2K
  • 2
<Runninhorn>
Guest
I just got a PPI A600 amp and need some subs (2) to go with my amp. I have had twelves, but never tens. Im going to go either 10's or twelves. BUT, what manufacture will hit hard, i like bass, with this amp? JL Audio, Eclipse, ? What subs do you suggest?
Will two 8710.4 Eclipse subs go well with this amp? are those DVC?
i would not reccomend either sub. i have found that JL oes not have clean bass, and you would need one hell of a big amp to power two Eclipse 12"s. i would reccomend the Kicker Comp 12"s or the Kicker Solo-Baric L7 12"s. they are the best for the money.
JL 12W0s for over all sound and value.
@ $150 apiece you can't beat their sound quality and power handling.
If you want to spend a little more try Infinity Perfect.
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
942
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
Guest
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
