What subwoofer setup would you recommend pairing with a Memphis Audio SRX500.1D Monoblock?
Slayer16102
CarAudio.com Recruit
34
It needs to be either a single 8 or 10, dual 8 or 10, triple 8, or a single 12 in a small sub box.
37716
The box cross section for the trunk is only 15" for a box to fit inside before it can be pushed forward to the partition. Any box deeper than that won't go down inside the trunk to slide it forward.
Once the box is down inside the trunk, it has to slide under the trunk lid lip, then forward to behind the seats. The max height here is 15" inches also just like the trunks cross section
37717
The box then stays hidden under the trunk lid's partition.
37720
This is the amp aswell as the specs.
37718
37719
Please tell me what you recommend for this car that will fit in its very tight trunk space and still make a good amount of bass too.. I primarily listen to rap and hip hop. The max size the box can be is 47x15x15
You have plenty of room to get a pair of 10s in there ported or Aero-ported
Wire to a final 2 Ohm load for that amp and should be fine. Look in Box Design section and see if Buck can get you a properly tuned enclosure design.
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
396
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
Slayer16102
Slayer16102
audiobaun
Brendon Jenness
    May 8, 2024
    May 8, 2024
