What to set my amp's Low Pass Filter and Subsonic Filter to?
  • 3
trenthonda1
Florida
I have a Skar Audio SK-1500.1D wired down to 1 ohm on a Fi Audio BL 15'' in a ported box 3.25cf. I need help setting the the Low Pass Filter and the Subsonic. Here are the specs, Low Pass Filter @24dB Slope : 35~250Hz, Subsonic Filter @24dB Slope : 10~50Hz And if it helps i mostly listen to hip hop/rap. Right now idk whats its set to but when i turn the sub up it sounds like the sub is bottoming out?
---------- Post added at 10:30 AM ---------- Previous post was at 10:29 AM ----------
Oh and the Phase Shift???
6
496
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Voltage for the signal? What does that mean? Electricity isn't measured in purpose. Gain is a characteristic of a circuit. You aren't adjusting...
20
6K
Sundown SIA1250. You can wire it to one or two ohms and get the same power. Don't wire it to ½ ohm.
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
8
847
trenthonda1
trenthonda1
Florida
Below20hzonly
