What was your worst car audio mistake ...
drpeeb
FL
... be it some (dumb) mistake during an install, or whatever, but of course most preferably ... your story of how you burned your car to the ground!!!
//content.invisioncic.com/y282845/emoticons/blow_up.gif.f2a780e8b12ae09e264cb01720b8dca2.gif
Let's hear 'em!!!
Top 5:
Buying a Sony amp/sub/box package from CC for $210 plus $75 for install (first system when I was 15). Dropping my 9835 faceplate and scratching the button. Accidentally touching the power wire to my buddy's amp's heatsink when installing it. Buying CDTs from woofersetc. Spending money on changing my setups before spending money on sound deadening.
Top 5:
x2
Never really done anything too stupid, except getting shocked many many times.
I guess building a box for my bros MB Quart 10s and not having any kind of idea of airspace, when i was 14. Just built a general box out of 5/8" MDF, ended up being like almost 2ft3 per 10. But it worked out pretty decent since he was running a Pyramid amp that put out like 150 watts per sub.
Let's hear 'em!!!
So far my own dumbest one was during my front door speaker swap-out ... Put in a baffle, didn't check the window operation, & now my window rolls down and hits it! No damage, just a pain in the @ss since I gotta open the whole d@mn thing back up and fix it ... and until I do the window can't be safely rolled down.
used a screw on terminal to attach some 2/0 to an alt feeding a bank of batts in the back. and no fusing. set screw backed off and dropped the 2/0 onto the engine. small fire resulted.
I only have 2 stories.
I dropped one of those metal holders that connect to the power wire and touch the fuse in my engine bay and lost it forever.
Making mdf adapters to fit my mli65s in my factory 6x8 holes. Speaker ended up touching the door panel when everything was installed. I got mad and destroyed the adapter and door panel. Took out the mli65 and put back in my infinity.
First system
rampage HU with no memory WTF???? everytime I turned it on/off it started the CD completely over
front fill- lightning audio 4s (off HU)
rear fill- eclipse 6x9, xplod 6.5s WTF???? (off 175x2 performance teknique)
Phoenix Gold Rsd 10 ( off another PT 175x2)
8ga wiring
FTL!
Ooooops. I knew there was a reason for fuses!
Allowing my friend to install a sony xplod sound system kit in a 97 saab and 2 50 dollar wolfenhagen sub kits in there ass well. But of cores 2 weeks later everything was upgraded. Blown a few fused in my time but lesson well learned. Wiring a sub to 1 ohms to a amp that wasn't 1 ohm stable "that was a error that almost fried the amp but didn't thank god"
My first car and stereo consisted of 2 MTX Roadthunder II's in a bandpass box in the trunk, a 12" Soundstream sealed in the backseat and a JDL (Japanese Dynamic Labs) amp pushing all of it. I had no clue about ohms and rms; I just hooked it all up and ran it for over a year that way.
LMAO did that 3 weeks ago in my moms honda civic installed a set of arc audio foose addition speakers in the doors now I have to get a spacer ring.//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Quit talking nonsense and acting like you know something... It's ok to be new...ask legit questions and you can get legit help...but right now...
9
152
Don’t do it on the ground wire. If you lift the amps main ground and the amp tries to ground through the RCA cable shield, you can damage the head...
14
Check for a blown fuse (or fuses). Referring to the car and not the amp. How do you have the amp wired? Power is directly to battery and ground is...
any links to free chat gpt 4 access? I haven't been able to find anything that isn't behind a paywall.. I want to take this cyber bish for a ride.
29
3K
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
192
drpeeb
drpeeb
FL
x1le
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
