What was your worst car audio mistake ...
un screwing my girl friends stock speakers and the drill slipped an went through the 260$ comp set she just bought //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
built my first box with my gramps out of 2x4's and a sheet of plywood
I was cheap and didn't want to spend $20 on a wiring harness, just cut the wiring behind the stock hu. Took my then GF back home and rode with the hu just laying there instead of securing it. Went to accelerate and the hu dropped out. Power, acces and ground wired up and power no longer worked. Had to run a wire from the fuse box.
letting a retard have access to my trunk. He wanted to test a sub in box, so while car is running, he unplugs speaker wires, lays them down touching, and fries my amp and HU.
holding the positive speaker wire in one hand and the negative in other while the car was on ha. zzzzzzzzap.
Quit talking nonsense and acting like you know something... It's ok to be new...ask legit questions and you can get legit help...but right now...
9
152
Don’t do it on the ground wire. If you lift the amps main ground and the amp tries to ground through the RCA cable shield, you can damage the head...
14
Check for a blown fuse (or fuses). Referring to the car and not the amp. How do you have the amp wired? Power is directly to battery and ground is...
any links to free chat gpt 4 access? I haven't been able to find anything that isn't behind a paywall.. I want to take this cyber bish for a ride.
29
3K
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
552
drpeeb
drpeeb
FL
x1le
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
