Whata are these, any info on them???
  • 2
Officialde.6
CarAudio.com Newbie
My pops had these in his old Tahoe, I plan on putting them in my new yukon, any info on these would be greatly appreciated
POWER ACOUSTIK FARENHEIT MXW-12S SUBWOOFERS. Try looking them up they have yellow ones (another model) and other old school subs. If I remember correctly they handle 600 watts so they said. But do more research on the power handling it's been awhile since I've seen a set of these. Check your foam surrounds etc. Good luck.
https://lorong-6-toa-payoh.singapor...s-10inch-subwoofer-speaker-unused_720747.html
Found some 10's on an old Singapore site here's the add if you want to see. There are other sites around just look.
Farenheit 10-inch Subwoofer Speaker . 1 unit unused
model: MXW-10S
by Power Acoustik
2-inch high temperature voice coil
Magnet 60 oz
Impedance 4 Ohm
Max input 600 Watts
RMS input 300 Watts
Frequency Response 35-3Hz
Sensitivity 92 dB (1W/1M)
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
12
791
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
First of all you would want to verify that it works. Next, don't expect to get much out of it. There's a rather finite life expectancy on...
I found the paper from when i was looking into compatible impedance's close to Bose HU... Cleaning out basement, lol found this and realize how...
14
Officialde.6
CarAudio.com Newbie
Officialde.6
Flroida
billyg
Decebal
    Jun 10, 2024
