What's a Good port dimension
  • 2
Jglaser
So I'm taking my sealed sub box and turning it ported for my 2 12" alpine type r's both having 1.53 cubic feet already put a 2" port in tuned to 38 hrtz but I'm getting this weird flapping sound from them it's not the subs so I suspect it's the ports would it benefit me and will it maybe fix the flapping sound if I bump the diameter to 3" and tune it to 32 hertz the sound is like there paper in front of the port but there isn't it is rather bothering me
Scrap that sealed box. You dont have close to enough space to do ported after displacements. For two 12s you need at least at 6 inch aero port, not a round port, AERO port. If you want to use just normal round ports, you need an even bigger diameter.
free box plans
*OFFICIAL* Free Ported Box Plans (56k NO!!) - Dodge SRT Forum[/u][/b]
Use this program to design a box based on the space you have. Tutorials on using the caculator on the page along with download link.
Torres' Box Tuning Calculator - Updated 8/18 - Subwoofers / Enclosures - SMD Forum
Then plug the sub's parameters in this software and then plug the box specs in and see what kind of sound you will get, spl possibilities, port noise/rear air velocity you biggest problemetc...
LinearTeam
tutorial for WINISD
What size diameter I have a very limited space I have 51" length but only 10 inches depth has to fit under my back seat of I were to keep my current box what size diameter port do I need
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
848
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
994
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
Jglaser
Jglaser
Pleasanton tx
Jglaser
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
