what's the difference between 4 ohm stereo and 4 ohm mono?
with your amp,you will get 200x2 when its bridged,which means,taking 2 of the 4 channels and making 1 large channel.1 large channel per side.usually you bridge smaller amps for subs or more to components.
50 x 4 @ 4 ohms
100 x 4 @ 2 ohms
200 X 2 at 4 ohms bridged
with your amp,you will get 200x2 when its bridged,which means,taking 2 of the 4 channels and making 1 large channel.1 large channel per side.usually you bridge smaller amps for subs or more to components.50 x 4 @ 4 ohms
100 x 4 @ 2 ohms
the specs on my amp reads
50 x 4 @ 4 ohms STEREO
100 x 4 @ 2 ohms stereo
200 X 2 at 4 ohms bridged MONO
my question is what's the difference between 4 ohm mono and 4 ohm stereo?
Mono/monaural, means you have a single channel of audio. You can either have your left and right working separately and have stereo or you can combine those two channels for a single more powerful channel but you lose the stereo separation. On your four channel you can do this twice. So you can have 4, 3, or 2 channels.
what do you mean stereo separation?
anybody know the difference between 4 ohm stereo and 4 ohm mono? i am trying to bridge my amp, a diamond audio d3 400.4 and it says it will do 200.2 at 4 ohm mono but 50x4 at 4 ohm stereo.
a mono amp is 75+/- efficency while the stereo is 65+/- efficency.
thant means a mono amp will give more power than a stereo amp
Just read what I posted...
If you are running off of the factory radio (mono) the amp makes more power to compensate for a poor source. If you have an aftermarket stereo (stereo) it has a better source and doesnt need to produce as much power...
no, no, no.
a HU never dose that, but correct each have differrent SQ
A HU always dose that...
You must be describing the antenna function which will switch to mono to compensate for a weak FM signal.
Are you really under the impression that your stock radio's amplifier switches between mono and stereo based on power needs?
According to the Taramps site, there are three variants: TARAMPS SMART3 BASS 1 CHANNEL 3000 WATTS RMS 0.5 ~ 2 OHMS CAR AUDIO AMPLIFIER. TARAMPS...
I can hear the difference. A typical component system will have a superior tweeter and crossover, although I've noticed component crossovers are...
Just thought I'd quickly update this thread as it's been a long while since I promised an update, I finally checked the AC output of the speaker...
23
6K
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
392
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
780
doublevision
doublevision
nj
drpeeb
