When Installing amped comps...
  • 4
If your rear speakers are connected to each other or the same power wire then yes , but if you are able to have one speaker play at a time (Front Right, Front Left, Rear Left, Rear Right) by just changing the setting on you HU (Deck) then no, it will not change the impadence of you rear speakers.
This links shows impadence when two speakers are connected to the same power wire.
http://forums.caraudio.com/vb/showthread.php?t=31984
No. i was serious. Sorry to confuse you. I was laughing at ur predicament when he just said no and u didn't know to which question.
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
423
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
DOHCrazy
DOHCrazy
Dallas, TX
kuijo
