where to ground
i usually use one of the bolts on the shock/strut tower......sand down the paint and use that bolt. suspension components always are bolted directly to frame so you know you get a good frame ground
HAHA wow.. this is not a question forum.. Go to a different section!!!
This is for build logs...........
x2 but if you have the second battery near the amp then why not ground it to the battery?? I'm sure you have THAT battery grounded to the frame somewhere don't you?
ground it to the 2nd battery if you have it grounded to the first battery, that's what i did //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif 2nd battery must be hooked to first battery, or defeats the purpose.
use the battery
use the battery
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif that's what i said, it just seems unclear is all
lol sorry for the wrong section. I meant is it better the ground the amp to the chassis or grounding it 2 my second battery saying that my 2nd battery is already grounded. Cauyse its a shorter distance from the ground position on my batt then trying to find a spot on the chassis
mazzasec
Banned
mazzasec
ATL
na_rsx
