Cruzer 10+ year member
- Thread Starter
- #16
ah i see what u mean now. so i would still have to remove the console for box volume. thanks ill have to check it out and see if i can fit a 10 or 12.If you put the sub firing back and a little behind the seat it will fit with out any issues.
ya right behind the console, i drew up a box plan to take up as much floor as i could and leave the seats by the doors to fit adults and have leg room. problem is mounting the sub. its not wide enough at any point to mount a sub, so i would have to go up and somehow flare it out, and with pure mdf idk if i can.Plenty of room in the back, I would just sacrifice the middle of the rear seat and either build a small enclosure on the floor (thus dividing the floor space and leaving the seat untouched) or you could ditch the center part all together and build a larger enclosure using the floor and seat space.
cant ditch the center part, its a 60/40 bench seat, u either remove 60% of it, or 40% of it. cant remove the center unless i cut the seat and sew up where i cut to leave the side seats. if i never intended to sell the truck i would do it, but no idea if ill keep it.
currently have the subs sitting on the back seat, they fly around when i go around a corner lol. which is why im wanting to fix it.Screw just do what I did and fill up the back seat.... Or lift up the 40 seat abd but a box there so then you still have the 60 for 2 people
i did remove the 40% bench seat and i had a fi 15 ssd and tried a dc lvl 3 15, worked great i got to have the subs i wanted, but looked funny and i dont think 2 adults could sit back there with the little middle seat
