Which of these 2 subwoofers?
Konstantin
Chile
A little background: I have an 08 Impreza hatch, so I have very little trunk space. I currently have 2 amps back there plus a 12 inch sub, and they render the trunk useless. This is why I have decided to get a new 10", and re-arrange the amp placement.
I have narrowed it down to these 2 choises:
DLS Nobelium 10":
- Woofer size 10" (25 cm)
- Impedance 4 ohm x 2
- Power handling capacity 500 W RMS
- Max power handling capacity 800 W
- Peak power 1000 W
- Frequency range 25-2500 Hz
- Sensitivity 83 dB (1W/1m)
- Magnet size 180 mm (7,08"), 180 oz / 5,1 kg
- Outer diameter of woofer 266 mm (10,47")
- Mounting depth 150 mm ( 5,91")
- Mounting hole 236 mm (9,29")
- X-max +- 14 mm (0,55")
- Weight 9,8 kg (21,6 lb)
CDT Audio QES-1020:
# Frequency response 10Hz-400Hz
# Power handling: 500WRMS (1000Watt Pk).
# Impedance 4 Ohm
# Sensitivity: 84.4dB
# Mounting depth: 5.71
# Cutout diameter:9.19
# Cast frame: OD 10.19
# Cone: Mid/Kevlar-paper Honeycomb
# Magnet weight: 134 Oz stacked
# Cone surround: NB rubber
# Impedance: 4Ohm
# Voice coil: 2.6 (66mm)
# Fs: 39.8Hz
I am looking for SQ this time (the 12" is a S12L7), and from reading opinions CDT seems like a good bet, and I know DLS is good as well. Due to the fact I live in a place where high end car audio is not so prevalent, its the only good choises I have.
Based on the numbers up there, which would you get?
Oh yes, the sub will be powered by an Alpine PDX-1.600
$350 budget there are soooo many options
dayton ho(10" rated 600 watts and costs $127 new)
AE AV (10" is rated 750 watts and costs $190 new)
those are the ones i would go with but there are more as well
IDQ 10 $240 new, rated 500 but will take 600np
its almost like no one even read your post.
is it possible for you to order something in your country on the internet? because that is a definitely a steep price to pay for what your getting. you'd probably get a better deal buying something in the US and having it shipped to you.
Yeah, not many read the thread it seems.
Ordering via ebay is not an option because shipping costs are huge. Around $250 por like a 30 pound shipment, plus 30% customs tax upon arrival. No dice.
what type of enclosure and car is it going in?
actually,
in the right enclosure i'd bet the difference between the two is minimal so i'd go the cheaper route: cdt.
psst, guys, he's in chile! SA 10's are out of the question.
My vote is for the cheaper of the two as well. Unless for some reason that DLS can dig lower that the CDT in a smaller box. Model them both up in winisd and see which can perform better in the small enclosure you are looking for.
I guess I'll go wit the CDT, can't be worst then the kicker s12l7 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
420
Lighten up man, it's all in good fun. Having more to go on than I want a sub that is less than 6" deep heps the forum narrow the focus. Why...
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Konstantin
Konstantin
Chile
Jay Mack
