Which Sub Should I Get?!?!
Quadrider10
18
Jersey
Whats up Guys of the Interwebs?
My name is Patrick, and im trying to setup my first system.
So I've been messing around with my audio setup. Currently I have a 04 Mazda 3s. It has the stock head unit in which i added an LOC. Im using 8 Gauge power wire to the amp, and 4 Gauge Ground wire from amp to the chassis. I Just finished the Big 3 Upgrade using 4 Gauge wire. As for the Amp, i have an AudioPipe APSM-1300 Mono Block. It runs at 400W RMS @ 4Ohm, 650W RMS @ 2Ohm, and 1000W RMS @ 1Ohm. So with these specs. I've been debating on which sub to get. I have a ported box. I've been debating between these 2 subs:
Soundstream T7.104 (t7104) 700W 10" Tarantula Series Dual 4 Ohm
And
Rockford Fosgate PUNCH P3D4-10 10" P3 Series Car Subwoofer
I'm planning on running at 2Ohms @ 650W RMS. Any ideas on which sub to get? or any other recommendations other than these to? my max price is $130.
soundqube then. tend to work in smaller boxes. atleast that's been my experience with them
---------- Post added at 03:01 PM ---------- Previous post was at 03:00 PM ----------
Do they have a link to the yard sale? I keep reading about it, but don't know where to find out about it...
somewhere in here Sundown Audio
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
Have you check to see if the prefab would fit...
13
It's fine to mount to the box. A lot of show car SPL setups have amps or other electronics mounted directly to the wood frame of the box or on an...
21
236
Quadrider10
Quadrider10
Jersey
Quadrider10
Decebal
    Jun 10, 2024
