White Noise from Tweeters Help!!!
I should have used 'noise' in lieu of 'engine whine' to not be specific as the same concept applies.
youre picking up induced interference from an energy source, which has been found on many occasion to be caused by, but not limited to, faulty alternators, faulty batteries, faulty ignition components, or faulty wiring.
Rca's used to be the main culprit until noise rejection topology had advanced to negligible returns, so to be fair, i do not believe you have a problem with your signal patch after 2 replacements.
Does the noise exist with the engine off?
Does it exist with the engine on, but the battery disconnected?
It would be a shame to see you replace the source unit only to find you have the same issue from not eliminating all forseeable possibilities.
Idk, it could even be from an outside source like a cell phone or wifi hotspot signal, or a wideband security system. Rare, but entirely possible.
It down to trial and error at this point. The only expense is affording the effort to be certain.
I haven’t upgraded the big 3. Could that be a factor?
I skimmed the manual and did not see any mention of a reset on that model, so bummer if leaving the power disconnected did not help. Maybe Pioneer...
10
4K
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
Gabriel7960
CarAudio.com Newbie
Gabriel7960
Florida
Jimi77
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
