Who has the best amp????
Go to Walmart, pick up a dual amp. Those things are the cleanest amps I have ever heard.
Apparently you haven't heard the Pyramid amps, 5000watts under $100 = the BEST //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i currently have a hifonics bxi 2608. im still new to car audio i want to get a stronger amp but i dnt know who are the top companies are. So if any body has some suggestions help me out wit who u know or make a list. Thanks
Like everyone else has mentioned your question is very vague we have no idea how much power you need or what ohm load you need to run at but I would say mmats but since your current amp is only 400 watts shy of the mmats 3000 amp I'm guessing you want more than 3000 watts.I would suggest looking into Sundown,Dc audio , or Digital Designs .
I prefer boss amps myself. Its the only brand that can make 4000 watts and not strain my stock electrical.
meh at best
Not cleaner then my Rampage I got from Autozone
i got one better
sry for making a general question. I have a ford escape. The for cyclinder wit a small battery smh...but i added the battery from an Grand Marquis to help me out wit power also getting a Yellow Top pretty soon. Upgrading my altenator also... I want to upgrade to an 18'' sub between 2000-4000rms. i havent really decided yet on wat sub yet but i know its gonna range between that for power. Like i said b4 i already have an Hifonics bxi2608 In all i dnt wanna spend no more then $1500(not including Yellow Top & Alt) for my setup. So no more than $600 on da AMP and i guess i'll just build my system off of that.
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
I use these and they work great. I splice them right before the LOC. One leg on the negative the other on the positive.
My 1964 fender vibroverb. It’s a tube amp for guitar. It has broken many times. But it is a serviceable amp. I can fix it.
73
13K
swalk386
swalk386
Deltona, FL
BnGRacing
    May 19, 2024
    May 19, 2024
