Help tuning my amp
  • 1
silveradokid
The Hope that lies WITHIN
So on my amp it has an input gain setting, a switch that has two settings .1V-1.0V and 1.0V-8.0V, I figured out my head unit puts out 2-3V, but when I switched it from .1V-1.0V it was not nearly as loud, I'm wondering if it would be bad to run it on the .1V-1.0V instead of the 1.0V-8.0V? The only difference I noticed is that my subs were a lot quieter and they sounded better, just not as loud.
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
5
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
I may have missed it, but do you have sound deadener on the doors? If not that could be why you're lacking midbass.
864
Do you intend to drive around playing test tones? If your intention is to play music, you should be using music you intend to play to dial in...
9
silveradokid
silveradokid
Orange County
silveradokid
Mr FaceCaser
    May 19, 2024
Mr FaceCaser
    May 19, 2024
