who too trust on box tuning aka port length ect.
  • 5
rrob69ewf
10
boise
Ok I have been all over a few sites trying to find the correct length of port for a box I am building for my 06 gmc crew cab. I already have it built... 2000 cu inches after the sub. figure about 90 cu inches for the port at almost 13 inches from what i can figure. that is aprox.
my problem is I go to different sites and get different lengths on the port varying about an inch. I would like to get this right. I am looking to get 33 hz if possible
if i do the math it looks like 13.6
i get on different sites and it looks like 12.2-13.9 kinda seems like a big difference
I also tried the winsid program and it just kicked me in the jewels.. I could use some help if someone doesn't mind.
btw these are soundstream SS10Rs one per chamber
I would use a single chamber. RE's calc works pretty good far as I can see for tuning. I doubt if one inch difference is going to be something you can hear and barely measure.
carstereo.com has a calculator that is actually correct. RE's calculator is definitely not accurate. In reality though, you probably really wouldn't notice the difference. Some of the calculators don't factor in end correction for slot ports which makes a difference.
ok I did notice that end correction but it was asked on round ports as well... what is the end correction? I am not up on this I appologize just getting back into this after a long few yrs. Not prison.... kids kind of the same though teenagers lol
i think end correction is where the port comes to the back of the box, and makes the L shape, 2 things happen. it doesnt go all the way back to the back wall, there is still the port width gap. also where it makes the corner of the L, its a little longer than the port width.
The Torres App is really good .. it factors in sub displacement, bracing displacement n such .. also gives u better options as far as ports as opposed to the RE calculator that only gives u a slot port option.
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
rrob69ewf
rrob69ewf
boise
audiophile831
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
