why dont more people use fi ssd
You joking, right?
I remember scott saying the dual motor SSD with flatwind coils was like the SX (original). Both these subs are under rated. I am not sure how much better the single magnet SSD is compared to the old one.
nope im not joking, Overall I bet the SSD is a better driver then the Older SX was, and besides the XBL^2 motor and nuthugging the Q is a better more efficient driver then the older XXX could ever be.
SSD>SX
Q>Older XXX
SSD>SX
Q>Older XXX
Of course it is more efficient, since the XBL^2 coil/motor design wasn't made to be loud. It was made to be provide very clean output over a larger amount of linear stroke. In your opinion, what makes the Q "better" besides efficiency?
I've heard the 05 XXX in person, and I really can't imagine any sub sounding as good for how loud those things were. Sure the Q has the same intention, I just can't see a sub being better than the 05 XXX for $250.
dude has 3kw! story brah!
i have 6kw and i'm planning on swapping my hdcs for 4 sa-15s //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/boink.gif.91933e72f927f2cefc79aff02573090c.gif
No, not unless it's using a different coil or motor.
lmao, did u read the thread or did u just jump to my post and read it?
some guy said an 18" with same coil and motor would take more power than the 10" version.
helo told him no.
i agreed with helo, then jokingling said idk... big subs adds power handling!
helo told him no.
I did not say "with the same coil and motor"
I assumed that the 18 would use different soft parts, which was obviously a poor assumption on my part. From what I have had experience with, the 12's, 15's and 18's of the same model line generally have upgraded soft parts over the 8's and 10's. I guess I haven't played around with enough subs...
i wasnt bashing u or talking bad, u probably know more than i.
was just pointing out that he didnt read the few posts around mine, just singled me out lol
Even with different surround and spiders, the thermal power handling is determined by the coil and the motor. The only lines that I've seen that use the same coil and motor throughout the line that have an increase in power handling as the drivers get bigger all have aluminum cones which help dissipate heat.
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Ill check it out. I was actually on the site last week. Thanks!
602
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
752
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
907
1rockford1
Banned
1rockford1
soon to be upstate ny
1rockford1
Decebal
    Jun 10, 2024
