Will my stock Mazda 3 alternator be enough?
  • 1
Sephious
Let me start off by saying, after my system is all said and done, I'll have two amps, one running at 250-300RMS, and one running at 1200RMS. Theoretically around 100 amps of max power.
If the big 3 is done and my alternator is 90 amps, I'm not going to have enough power, am I? This makes my heart sink, as high output alternators apparently don't exist for Mazda 3's because their output is regulated by the ECU.
Is there any workaround to this at all?
EDIT: Now I'm reading that the ECU only controls voltage and doesn't care about current so that a high output alternator would work, and that some do exist. So much conflicting information! Does anyone know what is true?
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
716
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
887
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
579
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
677
Sephious
Sephious
Saskatoon, SK
Sephious
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
