will this new upgrade be worth it!! please help!!!
Gatman
Hello people, i want to build a new system for my car, but idk if it will be worth it. Im planning on having two Digital Designs 1512 woofers in two seperate ported Enclosures, because my trunk is too small for one huge box. For power i will have two sundown SAX 125.2 amplifiers rated for 800 Watts a piece. What do you guys think? btw this will me in a 05' dodge stratus sedan if it helps!
just get a sundown 1200 and another 1512 then use your old 125.2 for your front door speakers or sell it. having two amps on separate subs tends to lead to phasing issues if not gain matched properly.
yeah, if it takes a few months to save up more for more power it will be less headache when u wanna upgrade in the future. don't upgrade on some kneejerk reaction cause u will find yourself with stuff you don't really want or won't fit into a system down the road, been there done that. just my .02
so i should go with one amp instead of the two, for the ease of tuning and space, and i could keep or sell my sundown for 200 since its like new (can get them for 250 plus) and save some money also lol....anyone want a sundown? lmao
well realisticly the amp pushes maybe 550 real watts...someone also told me the sax 125.2 is for mids, not subs...so the question is...would i be better off with the Mmats 600.1 or two sundown sax 125.2
If you like the sub you have, then continue to run it. I would look at what improvements that could be made to do some deadening and maybe port...
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
637
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
764
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Gatman
Gatman
Milbank, SD
Ineed$
