Winning? (Amp question too!)
  • 2
Xinspaly
So, today, i decided to get rid of my IA LI 15's.. i got them for dirt cheap, 250 for the pair.. and got a little bit of goodies as a trade for them.. i didnt have room so my goal was a single 12 (TC9 motor, random softparts? But it looks beefy as hell with a HUGE tall surround) I ended up getting the following-
TC9 based custom 12
Rockford Fosgate 2.9x
2 Rockford Fosgate Oldschool Punch Z 12's
Memphis 16MC3004 4 channel amp (needs new power supply he said)
Is this a good deal do you think? The tc he said handles 1000+rms alone, and the RF 2.9x will be powering my rear stage.. How hard do you think it would be to replace the powersupply on the Memphis? this thing is chunky and looks smexy.. PS(What type of box should i put that 12 in? Idk if i should make it bigger to handle my 1000rms Massive N2 amp better or not?
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
311
6
452
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
741
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
541
Xinspaly
Xinspaly
St. Louis
Xinspaly
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
