Wire... 50'
Just go to Knu man. Cheapest you're going to find.
pretty much... I am suppose to be picking up the vehicle tomorrow and was planning to just order Knu then but figured someone might be tearing something apart or some ****. It never fails, when I buy something new, the next day someone sells some slightly used **** for 1/2 the price...
Morning Kevin/
You must be *Patient,GrassHopper*...lol/jus' kiddin'/=O].Did you ever get the 1/0 Cable you wanted? How about *Welding Cable*?
I'm gonna be using *TryStar 2/0 Welding Cable*,Red & Black in Color in my Stang/;O].The company was kind enough
to send me a Sample pieced,to make sure it would fit into the barrel of my StreetWires 1/0 Gold Power Rings,w/Set Screw.
It fit right in.It's not,as I'm sure you know a *High Strand Count* like: *Knu/Stinger/Monster/Kicker/Etc.* but,I've never had
any *Issues* w/using Welding Cable in my SC2/Saturn.
Everything under the Hood of the Stang,for Power & Ground connections,will have that 2/0 Welding Cable.Starter included.
Going to get some *Expandable Sleeving* from "Furryletters" on E/Bay,for under hood.I believe he also carries,some *TechFlex*.
I bought a 100 foot roll of 3/4"-I.D. Black Flexible Conduit,*Non-Metallic* for the runs under the Stang,coming from the Front Battery
to inside the Hatch area Battery,and use 2-45/Degree Conduit Fittings to go into the Spare Tire Well,for the Cable.No Leaks,No Nothing.
Ahhhhh...I talk too much,Sorry,my Friend/=O[.
I hope you got the Cable you wanted/;O].Take Care,and have a Great WeekEnd.
Best Regards/
Raymond
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
88
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
556
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
902
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
873
k_schutte
k_schutte
cedar rapids, IA
MustangGT25YRS
    May 18, 2024
    May 16, 2024
