wire clarification
  • 2
kel789
NYC
i would like to clarify a few connections from a cheapo xovision touch screen into a 97 maxima. i already have the metra harness and the antenna adapter so here is the question. is the radio pink wire "lamp in" from the picture below suppose to connect to the illumination wire harness "Red/Blue" or the dimmer wire "Red/Orange" or none leaving the pink wire alone?
from the xovision head unit, there are 2 ground black wires on this radio. the braking brake brown wire needs a ground connection and i think reverse gear orange wire needs a ground connection as well. can i connect all 4 wires together into one large wire and connect onto a bolt or nut behind the radio or connect to the radio harness black wire to ground?
does it work to connect an ebay cheapo license plate camera to a tail light power source or is it better to connect to the Switched 12V+ Blue/Black. i would like to avoid reverse light because it turns on only when the car is in reverse.
many people are not able to answer these questions. it makes me think these wires are very challenging.
thanks.
pink wire:
Image hosting, free photo sharing & video sharing at Photobucket ... inwire.jpg
1995-97 Nissan Maxima Stereo Wiring
Constant 12V+ Pink/Blue
Ground Vehicle Chassis
Illumination Red/Blue
Dimmer Red/Orange
Antenna Trigger Black/Red
Antenna Right Rear
Front Speakers 6 1/2" Doors
Left Front (+) Blue/White
Left Front (-) Blue/Yellow
Right Front (+) Brown
Right Front (-) Brown/White
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
I would leave the pink illumination wire alone, not connected to anything.
The brown brake input wire just connect to the radio ground. This will allow you watch video whenever you want.
If you actually have a back up camera, then you want to connect the reverse gear wire to the reverse lights. This wire does not get grounded. You want to connect this to a Green/White wire in the driver door sill. This wire should change to 12v when in reverse so the camera will come on automatically when you put it in reverse.
And you want to connect the camera's power to a switched 12v source.
just out of curiosity, why leave the pink wire alone? why use switched 12v source for the camera and not the tail light?
regarding to the camera mode, the orange wire sounds like an automatic camera trigger. i like the automatic function but i would like the camera to be turned on while shifting gears forward and reverse so tapping into reverse rear light is not an option for me. is there another option to draw power from the rear? what happens if i leave this wire alone?
Thanks.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
287
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
777
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
953
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
946
kel789
kel789
NYC
kel789
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
