Wire Haress Help
  • 1
R3B3L 91
25
Indiana
I need help with a wiring harness for a 2004 Pontiac grand prix. I have found two that seem to be the cheapest but i wanted to know what the difference was between them in layman's terms. I see that The LC-GMRC-01 only has a 3amp 12v accesory but the GMRC-01 has just a 12v accesory. What does it mean by only the 3amps on the LC-GMRC-01? Would that be adequate for a aftermarket stereo (basic cd player)? Thanks Any help is appreciated.
EDIT:
So i figured out lc means low cost but im still not quite understanding the 3 amp part is that bad enough to just pay extra money for the normal one?
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
120
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
617
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
917
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
891
R3B3L 91
R3B3L 91
Indiana
R3B3L 91
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
