wire size for my systems amps.
  • 3
dieselwelder
I'm currently running a RF T1000 BD @ 1 ohm to two Sundown SA 12s and a Alpine V12 MRV F 545 running my Boston acoustics mids and highs... 125x 4 ... I'm currently running a 4 gauge power wire to the trunk where it splits to a 8 gauge to the alpine and 4 gauge to the RF. I noticed today I was having some power problems with sub output.... I think I tracked it down to my fuse on the 4 gauge ... Looks like it was just a tad dirty and the fuse and wire around it were getting hot...not melting hot but **** warm!! Anyway I was thinking about running 1/0 power cable to the trunk and 4 gauge to the alpine and 1/0 to the RF. My question is what size fuse would be appropriate for this size wire ?? Also I need to do the big 3 and I was going to use 1/0 for that too because my light dim bad .... Any other advice on upgrades would be appreciated.... This is a '98 Lincoln Town Car ....
What style fuse holder do you have? I melted one running 4g on my bd1001 when I had it. Never blew the fuse or messed up the actual wire but melted the fuse holder where the fuse slide in. Run 0g and the amp will do wonders for you.
It's a older stinger fuse .... It's plastic with two screw on ends and a fuse in the middle... A bought it a while ago... I think its a 60 or 80 amp fuse... I'm just goons get a larger power wire and fuse and do the big 3.... My lights really dim... I might need to think about upgrading my alt too.... The voltage display on the alpine said it was at 12.5..... Way to low!!!!
Tesla beat Edison. Why do you think we transmit high voltage ac? Cars are low voltage dc, which is absolute worst as far as efficiency goes, but...
61
4K
Agreed. I've used some very fine cable for +REM connections because I had it laying around and have had issues with it failing. Good quality...
5
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
391
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
875
dieselwelder
dieselwelder
Springhill, Fl
Bettr n' Revrse
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
