Wired Sub correctly?
  • 3
each coil is 2ohm? so DVC 2 ohm?
---------- Post added at 04:22 PM ---------- Previous post was at 04:22 PM ----------
if so:
Let me explain series and parallel so you understand. Series is the electrons leave the amplifier let's just say out the positive terminal, then flow into the positive side of coil 1, then out the negative side of coil 1. Then the negative side of coil 1 is directly connected to the positive side of coil 2 so the electrons flow through coil 2 and out the negative side which is directly connected to the negative terminal of the amplifier. Since the current had to flow through both coils before returning to the amplifier, they were said to be in series. This is why the impedence is added together. So if they were dual 2 ohm coils the electrons were faced with 2 ohms of electrical impedence twice thus equalling 4 ohms.
With parallel, the electrons flow to each coil independantly. The electrons flow out of the positive terminal of the amp and to the positive coil of both coils simultaneously. It simultaneously passes through both coils and out the negative side to the negative terminal of the amplifier simultaneosly. Since it had two paths at 2 ohms, the impedence was halved in this case. 2 ohms divided by 2 coils = 1 ohm. It doesn't matter how you wire it up in parallel. If all positives are together and all negatives are together, regardless how you got to it, it is in parallel.
thanks for the explanation! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
You are welcome. Subscribe to me on youtube. My chan is ecrackDOTnet. I actually just filmed this explanation last week. Haven't editted and uploaded yet.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
andriod detects sometimes iphone is connected i see it in the notifications but I'm guessing the app has a hard time knowing or its just a crap...
4
804
Tek18
Tek18
KY
ahole-ic
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
