Wiring for 4 subs.
  • 2
MitchZ
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=4&I=42
I plan on doing the 4 - four ohm DVC subs at a 2 Ohm load.
Whats the easiest way to wire from the amp to the subs?
It will be 2500 to 3000 RMS Amplifier @ 2 Ohms, each sub is rated at 800 RMS.
Would it be best to have 2 distribution blocks and go from Amp --> Distribution block --> each of the 4 subs.
Do the same procedure with positive and negative?
8 gauge or 6 gauge from the amp to the subs?
Thanks in advance,
Mitch
???????? wire it just like the diagram shows. you don't need a distro block. you don't need 8 or 6 guage wire either. 12 should be fine
Wire to the 2ohm diagram as shown for the MTX subs on the one amplifier you have. That amp should do very well on those two subs. alpine make some...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Sell the dual 2 and get another dual 4.
MitchZ
MitchZ
Victoria, British Columbia
illbmeubu
winkychevelle
    Jun 3, 2024
