Wiring from amp to sub for best results???
  • 2
djpheer
Hi, im new to this and i was just wondering how should i hook the wires up to my sub for best performance...... I will be running a JL 250/1 amp which is rated at 250 w rms @ 1.5-4 ohms at 0.05% distortion and one JL 12 inch w6 which is dual 6 ohm. Should i hook the wires up in parrarel to yeild a 3 ohm load? Or in series to make a 12 ohm load? Thanks
A good x-over point to start with would be 80hz. You can adjust a click up or down from there to suit your preferences. Beyond that I agree with all Jmac's recommendations.
two d2 subs can be wired to .5 or 2 or 8 ohms not 1 heres how to wire subs...
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
587
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
6
djpheer
djpheer
new orleans, la
Frraksurred
